Removing QDP - it seems very aggressive
Guest naughtydog
Guest naughtydog
Posted
I need to strip a rear window that I installed Global qdp on, I remember a while ago I removed some and even with steaming it can take some heater lines with it.
Does anybody have a failsafe way of doing it so I can keep mr picky! happy!
Thanks
  • Replies 23
Posted
Thanks
I believe there are way too many variables involved to have a 100% fail proof method that works all of the time (adhesive type, number of years exposed to the sun, etc...). With that being said, you may have to use a number of methods. It takes a bit longer but sometimes can be a good solution... trash bag and ammonia. :ppdance
Guest tintnmoreok
Posted
We also use several methods and, though nasty, the amonia technique is the one we've found the most effective and least damaging. That being said, I always caution the customer that while we will take great care in removing the film, there is a possiblity that some of the defroster lines may pull off with the film. If they are willing to assume that risk we proceed with the removal.
Posted
Thanks
Bingo, cant say the qdp dont stick.
Guest tintec
Posted
yes I to noticed removing even fronts with qdp the glue was super tough to get off,wouldnt like the chances on a back glass
Guest scottydosnntkno
Posted
a couple years ago when I used QDP, when I was removing the doors on my car, I found that while sitting out in the sun all day in the summer, the film just peeled off taking 95% of the glue with it. THere was just very minimal residue along the bottom edge that needed to be razored off :beach It seems like using a steamer would produce similar results
Posted
We sell "Tint-Off" by the case load. It's a product we heard about from several of our customers. They say it it's terrific.
-Howard
Posted
I've removed some qdp without any problems, often steams off with most of the glue. But I think blk baggin it with ammonia would be safer for the defroster lines.
Guest naughtydog
Posted
Well, allI can say it that I have tried the steamer before, and it was'nt great, so I want to make sure I get this off. Not seeing the car until a few days.
I have heard of tint-off but nver tried it. Not sure if we have it over here?
