2010 Outback
TintJunkie
Posted
Did one today. Easy, no shrinking except the back window. Panel pullers...do not attempt to pull the screw from the door handle and pry back the panel!!!!!!!!!!!!! The gasket is held in with bendable clips and the will "let go" of the panel. If you want to pull the panels, there are only two screws (door handle and grab handle) then you pop them off.
This came in as a r/r. Some ass clown did the back glass in two pieces and had trash everywhere in the film. Replaced with Wincos. I had to remove all the door panels the fix the gaskets b/c the original hack tried to pry back on the panel.
Posted
Where's the pics TJ? :bs
Aw poop. It was getting late and dark when I finished. Didnt bother with a pic. Guess I'll take one if there is an issue with a window. Which, of course, there wont be b/c Im an installer baller.
Guest Scottsfire
Posted
Well, thats good info to have. I'm a panel puller though....thinking of trying my hand at tucking. Any issues with the gaskets on the front doors?
