what is a Door Sanity
Guest solar solutions
Posted
what is a Door Sanity / V & U-Shape Tool?what is used for?
Guest TINTFXold
Posted
you put it in the hinge part of the car door and that pad part rests against the "ding-dong" button. It allows you to not to have to turn the key on while tinting and still not hear the door ajar ding dong
Posted
that thing presses the door plunger switch down while you have the car door open. basicly it stops the car from "DING DING DING" while you have the door open and the ignition on.
Guest TINTFXold
Posted
thats why its called "the Sanity Tool"..... you get to keep your marbles from NOT having to listen to the DING DING DING DING DING DING DING
Posted
all a nigga has to do is tint the driver door first then shut it, you can keep the other doors open and no dinging after you shut the driver door. :spit
Posted
all a nigga has to do is tint the driver door first then shut it, you can keep the other doors open and no dinging after you shut the driver door. :hmmm
Or stick your beer (can):hmmm into the driver door jam and do it first... :spit
Guest Litespeeds
Posted
Most cars will usually not ding dong if you have the key on the on position anyway.
Guest Sprinter
Posted
can also be used for the windows in a bmw to trick them!
