question about dry shrinking
Guest vital
Posted
sometimes when I dry powder shrink a back glass, I get two long horizontal fingers above and below the horizontal anchor... what do I do w/ these two large fingers that form across? also, I notice sometimes when I do a wet check it's hard to squeegee the water out because of those horizontal fingers which gives me a hard time layin the film down flat... am I over shrinking it?
Guest Sprinter
Posted
yes not a problem!
heres what you do. take you gloved hand and smooth them out going up and down then start your shrinking!
sounds like your pulling your tint to far side to side before the shrink if you can't get them down, now if you have to stretch your film once the shrink is done when wet checking then your over shrinking the film!
good luck!
Guest r26_1999
Posted
you are definitely over-shrinking. when I first learned this method, I would also get this problem and the film would never lay down. before you even star shrinking, make sure that you smooth the film out as much as possible and create verticle fingers. you don't want to shrink areas that don't need shrinking.
    rewiredtech.io
    2. 5
    6. 5
    7. 5
    8. 5
    9. 5
    10. 5
