L200 rear window
Guest pitstop-tints
Guest pitstop-tints
Posted
Hi folks not been tinting for that long and have a L200 warrior to tint on saturday. The rear window has a rubber seal and was juat wondering how easy are they to take out and how do I get it back in without the film lifting when I put it back into the rubbers.Any help would be appreciated
Cheers
Guest shadowline
Posted
I dont bother to take them out, cut them tight on the outside and install on the inside if you have to leave a small gap to get the solution out I do it at the bottom edge, this isnt seen from the outside and works well! If you want to remove then fine but I didnt need too, hope that helps!
Guest walestint
Posted
Cheers
they are easy to take out replace when you know how, you get a better finish, if unsure you could maybe get your local autoglass guy down to take it out/put back in so you can see how its done (that is can he pop back later in the day), but not to pay over the odds for him to do it of course :dunno
make sure edges are dry before putting seal back on, once seal is on you are fine, dont be tempted to use a tool on last bit of seal going in as it can slip and nick tint :piss take out and start again
:dunno
Posted
They are easy to take out/refit but can be done in situ. I used to take push them out and rope back in, but leave them in now and get just as good finish (well nearly)...
Guest pitstop-tints
Posted
Cheers
thanks alot for the advice .I t would be less hassle if I just leave the window in I think.
Guest pitstop-tints
Posted
where are you located Bonus?
I am based in North east Scotland. in a small town just east of Inverness.
    rewiredtech.io
      Sunscape dealers?
    2. 2
      Dealership Regional Lock Changed
    3. 2
    4. 2
      Looking For Tint Businesses for Sale in NJ
    6. 1
    7. 5
    8. 1
    9. 0
    10. 0
