Tip of the Week VOTE
vote
12 members have voted
  1. 1. vote
    • 1
      8
    • 2
Posted
#1 By "Breezy"
Hot Water, Direct sun flat glass tip
Hi all, have worked out an excellent way to avoid quick evaporation when installing in direct sun... Same soap mix has normal but fill your bottle with hot water rather than cold... when the water is close to the temp of the glass it doesn't evaporate. You may notice humidity under the film, don't panic it will dry out normally. Works particully well on big drops...
#2 By "skanlan"
drying out fingers(rear window)!!, especially on 2 doors!!
I use a blow dryer to dry out any finger that popped up on the rear window.doing it from the inside beats heating the glass from the outside then crawling back in to pushem out.Cause taking a heat gun inside is a no no I learned the hard way.I'm talking mostly about the 2 doors where you can't hold a heat gun with one hand on the outside and pushing the fingers out with the other..blow dryer + slammer wrapped with blue shop towel..or just blow dryer + blue max..Just lay em flat and hold position while the dryer heats from behind film tool!! for da 1 man gang!!
    rewiredtech.io
      Dealership Regional Lock Changed
      Sunscape dealers?
    3. 3
    4. 3
    6. 0
      Looking For Tint Businesses for Sale in NJ
    7. 1
    8. 5
    9. 1
    10. 0
