Hot Water
Guest Breezy
Posted
Hi all, have worked out an excellent way to avoid quick evaporation when installing in direct sun... Same soap mix has normal but fill your bottle with hot water rather than cold... when the water is close to the temp of the glass it doesn't evaporate. You may notice humidity under the film, don't panic it will dry out normally. Works particully well on big drops...
Posted
If you use that where will you keep the coffee? Flaugh.gif ... I get about 1 an a half hours out of a hot bottle before I have to top it up... I only fit in direct sun when I have no other option, most of the time I follow the shade around...
    rewiredtech.io
    2. 5
    6. 5
    7. 5
    8. 5
    9. 5
    10. 5
