04 tl
Guest turbob5
Posted
Hello, Im new tinting cars, but have been doing mobile electronics for 20 years so I decide to get into tint to help out with income. My problem is I did a 04 Acura TL a couple of weeks ago and I used felt on all of the doors. The tint job looked awsome. The customer came in the other day and said the right rear window was squeeking, so I looked at it and the window had pulled the felt down and got glue all over the window, Today he came back to scedule a time to fix it then he told me that the right front window is scratching. I checked the felt on it and it was good I don't understand what is happening. The customer is very cool, but this car a pain in my ***. when I cleaned the rubber to apply the felt I used denatured alcohol and cleaned until their was no black stuff on the towel before I applied the felt. any info will greatly be appreciated.
Posted
The 'scratches' are probably just adhesive smears..
Sounds like you either need better felt or a different approach to installing it :spit
Posted
Is there a better way to stick it other than just clean and stick? This is the first car that I have had to felt.
Posted
usually we just scuff w/ sandpaper, wipe down w/ wax & grease remover then apply felt..
I have seen the felt roll off of the lower of the 2 seals sometimes.. so we will wrap it up and over the 'top' of the lower sweep blade.. :spit
Posted
Clean with rubbing alchohol, scuff, clean with alchohol again, use an adhesion promoter, and before You apply the felt, HEAT the adhesive side a tad with Your heat gun. Holla! :spit
Posted
I had same problem when I first started felting.figured out I was pulling and stretching the felt on.after few days the felt would release and fall off.sounds like your doing it right ,make shure your not stretching it on.
    rewiredtech.io
    2. 6
    6. 6
    7. 6
    8. 6
    9. 6
    10. 6
