acura legend
Guest mrpain
Guest mrpain
Posted
hi all
just woandering what you use to lube the roll ups .
heres the prob im having , at roll up the window tends to slow way down and sometimes completly stop in mid roll up.
ive used soapy water( mostly soap......90 % soap)
ive used w d 40 and after a few dats the prob comes back.....
what do you use for window seal lube ?????
any and all help will be apreciated............thanks to all in advance
P . S.. 1988 4 door acura legend is the car above
Posted
we just use regular grease, but it doesnt completely fix the problem. the only way to fix it is to change out the regulator and all window channels. honda doors always get this way. the seals get tight and bent with age, this tightness then bends the regulators. so to get it back like new they both need to be replaced.
watch out. those 03-08 corolla's are looking real bad on the fronts, as far as rollup problems in the future
Guest mrpain
Posted
cool.....
thanks for the replay........VIP
I was just wondering if there was an easier fix , but ...............its ok ill have to do what you said .
thanks again..........
Guest mrpain
Posted
update.....
just used antiseize, afterpulling the panels, got that stuff in there real good
and go figure......
its good to go thanks for the tip V I P :thumb
    rewiredtech.io
    2. 6
    6. 6
    7. 6
    8. 6
    9. 6
    10. 6
