Contamination? Tips!
Guest CavScorpion
Guest CavScorpion
Posted
Well guys I'm trying to address this problem.
When I first started I couldn't shrink for anything - most windows now are easier.
So I'm getting a good finish shrink wise etc, cutting has always been easy, filing etc.
Whats letting my standard of work down now is contamination.
I don't mind on side windows so much - I've low overheads so if its bad I'll just strip the first one back off and retint which tends to get rid of most of it - however doing that on a hard window or a back glass is uneconomical.
I'm using a smear free window cleaner with a non abrasive scourer, a window blade and then rinsing with soap solution.
But still getting lots of contam - any tips?
Guest Paudraic
Posted
Blade the roll downs once window is clean flush rather than spraying window, flushing is much better than a simple spray. On back glass use a very fine wirewool and once again once window is clean flush rather than spraying you will prob find this will cut down on contam. :dunno
Posted
try not to touch anything with the film before puting it to glass
and try not to raise dust of the seats
getting in the car can contaminate the atmosfere in the car, more as the age of the car goes up
Guest Paudraic
Posted
:dunno Spot on m8! Another tip is before you install the film lightly mist inside the car that will hold down most of the dust!
Guest walestint
Posted
defo blade n flush
I use latex gloves (powder free) when transferring film onto glass then remove them one touched glass
mask up felt sides with 1" tape when felt is dry
dont sneeze onto glass :spit
on back glass I check with a small torch sumtimes for any nasties before final spray
Guest coolrides
Posted
I think where u are using to tint the windows can have a large effect on finish too. ideally a dust free room would be ideal but we dont all have such perfect conditions.
just keep the place as clean as you can and wet floors an walls if you can. but perfection is almost impossible in this game.
keep at it.
hey wales long time no see.
    rewiredtech.io
      Dealership Regional Lock Changed
      Sunscape dealers?
    3. 3
    4. 3
    6. 0
      Looking For Tint Businesses for Sale in NJ
    7. 1
    8. 5
    9. 1
    10. 0
