Felt....
Posted
Can someone give me tips on installing felt and where I can buy it? I need to do an 08 lancer and have no clue.
I tryed searching but found very little on this subject.
TIA!
Posted
CR Laurence sells it...
I prep the molding by sanding it with a 600 or so grit paper, then cleaning it with denatured alcohol, apply an adhesive promoter, then stick it to the molding.....
That's just my way..... :spit I'm sure others do it differently.
Guest krivera418
Posted
llumar sells it I think about $30 a roll you gotta take the door panel off it's time consuming but it's an up-charge :spit
Posted
Glue for the matrix????
I use Elmer's blue glue.... If that's what you mean.... :spit
No, glue for installing felt.
Does it come if adhesive on it??
the felt has adhesive on one side! :thumb
Great, thanks guys!!!
Guest thatsnappyguy
Posted
this is how I do it.
1. remove rubbers.
2. wipe it down with alcohol a few times.
3. take the heat gun or torch to the surface that the tape will be applied and just make a few passes to get it a lil hot.
3. apply felt, wrapping around the edges.
Posted
I use the felt tape that is pre cut into 1/4inch strips, so far I've only had one to come back not sticking....
Once I started sanding and using the adhesive promoter, I haven't had anymore return with a problem....
