VIper remote starter installation help
Guest Lefty19
Guest Lefty19
My brother is a mechanic and has installed a few simple remote starters. I purchased a Viper 160xv and he is having trouble with the passlock bypass thing. I also bought the 1700G "thing" to talk to the bcm. The problem is, how does he wire that exactly? The instructions are really vague. Is there a place I can get a schematic of the whole thing for my 03 Avalanche?
Guest CajunTinter
Hope this helps: :rollin
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / AVALANCHE / 2003 / Remote Start
12volts red & red/white + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
Power Unlock see power lock
Lock Motor gray driver door module in door
Unlock Motor tan driver door module in door
Parking Lights+ brown + driver kick panel
Parking Lights- gray/black - switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white - steering column
Turn Signal(L) green + steering column
Turn Signal® lt. green + steering column
Reverse Light lt. green + BCM, black plug, pin F
Door Trigger see notes - see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is black/white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. green/black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black + BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white ac instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white + brake pedal switch
Parking Brake lt. blue - switch or BCM, lt. blu plug, pin A7
Horn Trigger black/yellow to black - column or BCM, gray plug, pin B9
Memory Seat 1 red + driver door module in door
Memory Seat 2 pink + driver door module in door
Memory Seat 3 N/A +
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, black (org/blk), and red/white (not used).
Guest Lefty19
Thanks for the info. I will pass it on to him. Does this info explain the wiring for the thing that talks to the doors, passlock, etc? I do not know anything. I am passing this on. Thanks a ton.
Guest haroldshouseoftint
the module that works the door locks etc, attach the purple wire of it to the purple wire on the computer plug on the drivers side under the dash, really easy. as far as the passlock system goes, it's simple as well, need to drop the cover around the steering colum, and all the attachments are made there.
If he has mechanical/technition experiance, it's no problem :lol2
Guest CajunTinter
:lol2 :lol2 :lol2 :lol2
    rxactlite.com
    rewiredtech.io
      Vega Motorsport is expanding its Team. We need an Experienced Automotive Glass Tinter in Waldorf, MD. 20602
    2. 8
      Car Wrap HELP NEEDED
    4. 4,190
      What did you tint today?
    6. 4
      Dual Low E Question
      Dual Low E Question
    8. 9
      Any XPEL Dealers?
