Problem With Roll ups!
Guest ktown
I am having a problem with moisture bubbles up to a week after install. I use a yellow turbo like always. It is with different films as well. Any thoughts?
  • Replies 23
Guest Sprinter
you can start if you want to use a clear max or orange max or blue max I like the clear keep them sanded so they won't scratch and they all will move more water for you. It could be your film full metal takes longer to dry out and hey its cold out there where your at so it will take longer to dry.
Guest darkdan
blue max blade plus crusher handle.
Otherwise the thin blue channel blade with no channel cut to about 4" in an unger pro handle.
Squeegee good and hard, overlapping, slight angle, etc.
Welcome to my life.
Guest willie
All good advice. Use the blue max or orange crush and go over it a few times.
What type of film :rollin
keep that squeegee blade edge sharp no matter what you use. If your edge gets dull it will leave solution behind no matter how hard you squeegee.
I personally had problems with water bubbles being left behind when I tried a generic baby shampoo over Johnsons poo. I didn't have much problem when I switched to Joy, and since I have switched to Film-on I have had zero issues.
    rxactlite.com
    rewiredtech.io
      What did you tint today?
    3. 4
      Dual Low E Question
    4. 4
      Dual Low E Question
    5. 9
      Any XPEL Dealers?
    6. 9
      Any XPEL Dealers?
    7. 2
      Am I being too picky or should I go back?
    8. 9
      Any XPEL Dealers?
    9. 9
      Any XPEL Dealers?
