Venture Scratch Removal Tip
Guest Cpig
Here's something I discoverd last night while trying to remove scratches from VentureShield.
Most people know about using a heat gun to remove scratches but this wasn't working for some of my deeper scratches. So I followed the heat gun up with a LIGHT swipe with a MicroFiber towel - the scratches just disappeared and the film is now invisible again. The towel pushed the heat-softened surface together to seal the scratch. You have to use very light pressure immediately after applying heat for it to work.
Hi
Nice Tip
With 3M you can use IPA (ISO Propyl Alcohol neat) to get scratches out
With XPEL FILM You can Use De-natured Alcohol to achieve the same thing (Meths in other parts of the world) however anywhere in the world where meths has a DYE added do NOT use the dyed version on a yellow car it WILL stain it, track down the clear version (it is out there) of meths (or denatured Alcohol) and use that.
Anyone Got Tips for Avery and Llumar as I know a lot of Avery Guys would like some easy tips on scratches.
Guest goldtooth
nice tip will try it :evilgrin
