Valet 712T installation
Guest ocn
Posted
Recently acquired a 2006 Dakota which the ealer installed a Valet 712T. He can't find the manuals etc for it and I'd like to turn-off or disable the ignition -on locking/off unlocking feature.
Anyone have the installation instructions or wiring diagram for this keyless entry unit?
Posted
System Features Learn Routine
The System Features Learn Routine dictates how the unit operates. It is possible to access and
change any of the feature settings using the Valet®/Program switch.
TToo eenntteerr tthhee lleeaarrnn rroouuttiinnee::
1. KKeeyy..Turn the ignition on and then back off.
2. CChhoooossee.. Within 10 seconds, press and release the Valet®/Program switch
the number of times corresponding to the feature number you want to
program. (See Feature Menus.) Once the Valet®/Program switch has been
pressed and released the desired number of times, press it once more and
hold it. After a second, the LED will flash and the horn will honk to
indicate which feature you have accessed.
3. TTrraannssmmiitt.. The transmitter is used to select the desired setting. As shipped,
the unit is configured to the LED ON settings. These are the default
settings. Pressing the lock button will set it to the LED ON setting. The
LED will light solid (stop flashing) to indicate the setting. The horn will
honk once (if connected). Pressing the unlock button will change the
setting to the LED OFF setting. The LED will go out indicating the
change and the horn will honk twice (if connected
4. Release. The Valet®/Program switch can now be released.
For example, to program the arming mode from active to passive, within 10 seconds of turning the
ignition off, and press and release the Valet/Program switch once. Then press it again and hold it.
The LED will flash in groups of one and the horn will honk once (if connected). While holding the
Valet®/Program switch, press the unlock button. The LED will stop flashing and go out. The horn
will honk twice if connected. Passive arming is now programmed. If that was not the desired setting,
without releasing the Valet®/Program switch, press the lock button. The LED will light solid and
the horn will honk once if connected. Active arming is now programmed. Release the
Valet®/Program switch after the selection has been made.
You can advance from feature to feature by pressing and releasing the Valet®/Program switch the
number of times necessary to get from the feature you just programmed to the feature you wish to
access. For example, if you just programmed Feature 2 and you next want to program Feature 3 to
off, release the Valet®/Program switch. Press and release it once to advance from Feature 2 to Feature
3. Then press it once more and hold it. The LED will flash in groups of three and the horn will
honk three times (if connected) to confirm that you have accessed Feature 3.
The learn routine will be exited if:
➤The ignition is turned on.
➤The Valet/Program switch is pressed too many times.
➤More than 15 seconds elapses between programming steps.
System Features Menus
NNoottee::Factory default settings are shown in BBOOLLDD.
NNoottee::For feature number 1-4, the 3.5 second door lock pulse
setting the siren chirps twice, for the 0.4 second door lock
pulse setting the siren chirps three times.
Feature Default LED ON Setting LEDOFF Setting
Number (Press Channel 1) (Press Channel 2)
1 Ignition-controlled door lock ON Ignition-controlled door lock OFF
2 Ignition-controlled door unlock ON Ignition-controlled door unlock OFF
3 Ignition-controlled domelight ON Ignition-controlled domelight OFF
4 0.8second door lock pulses 3.5 second door lock pulses/0.4 sec.
5 Double pulse unlock OFF Double pulse unlock ON
6 Double pulse lock OFF Double pulse lock ON
7 Comfort closure OFF Comfort closure ON
8 Code Hopping ON Code Hopping OFF
Posted
Thanks for the info! Hopefully I'll find the valet switch ty wrapped to the harness under the dash.
