IN HOT WATER!
Guest carsho
Posted
When cleaning your water bottles use hot water. This breaks down the old solution that clings to the bottle and the sprayer you use. On the same note, use hot water when refilling your bottles. The hot water helps disolve the solution you use making it more consistent throughout your refill. This will also help on the gumming up of the solution that sometimes makes it to the application process.
Posted
also if you soak them in hot water and alcohol it breaks down all the lanolin once every 2 weeks is fine :beer
Guest Key West
Posted
Is this what TOTW has come to :hmmm
Yep! C'mon old timers. Surely to God we can come up with more time savers, or how to's that will help. Although this has to be one of the better, more innovative tips I've read here of late. (Sad, aint it? :spit:hmmm )
Guest FilmBlazer
Posted
I place ice cubes inside of my comm/res bottles and shake the :hmmm out of them. This helps loosen up any soap scum sticking to the sides of the spray bottle which is the teardrop sprayer until I get around to building my corny tanks :spit
Posted
Is this what TOTW has come to :spit
Is this what tintdude has come to. Atleast he's helping contribute to this site. Thats what I thought it was all about. I believe no matter how small or big a tip is it should be posted. It may not help you but it might help others.
Posted
:spit this tip may help some it may not help any but at the least hes contributing a tip for everyone to see for free. if you dont like the tip then oh well. this site is a well informative site that is free for people to view and use. if it was a tip that made no sense then maybe there might be a problem but to him it helps and maybe someone else might use the tip or even throw something else in to make the tip better or a different way that may be more useful. :hmmm
Posted
dont listen to that crap its very important to have a lanolin free bottle so you dont get chunks int the tint unless some like it lumpy :spit
