what is the coolest temperature to to do flat glass?
Posted
Hi folks:
For those who know Canada, We are already in cold temperature. few days ago we got a drop of temperature-15 o C, I have scheduled some appointement before the tem dropped;pnow it is kind of coldish, I am wondering if I have to cancel all the jobs as the night temp drop below 0 o celsius, I ma a fraid that the water below the film will iced instead of dry.
What do you thing ? :dunno
Guest vclimber
Posted
If your water bottles are not frozen, then go for it. :dunno
Just make sure you squeegee extra good. :dunno
Guest rcjello
Posted
I would think the warmth in the house would keep your liquid liquid. Use a bunch of paper towels and hard cards.
Posted
long as ya get as much water out as possible, shouldnt be a problem...I've done windows at -30 C. Just dont limp wrist it. :dunno
Posted
That is good to know :dunno I have been afraid for nothing
regards,
Reason for edit: Irrelevant link that has already been posted, please don't spam the forum, thanks.
Posted
Do NOT use hot or warm water unless you want to watch the glass crack.
As long as the water does not freeze on the glass, install away
Posted
Gotta empty those tanks and not leave water in them while they are in your truck overnight. Otherwise will take a while to thaw after a cold Canadian night.
Guest darkdan
Posted
Single pane, around freezing maybe a bit below.
Dual pane, just about any temp.
Posted
I've had moisture on single panes freeze after install. told 'em to leave 'em alone and let the film cure. film cured just fine. :nope
Posted
long as ya get as much water out as possible, shouldnt be a problem...I've done windows at -30 C. Just dont limp wrist it. :lol2
:nope
..and as mentioned above..single pane will give you grief..not that there's many single pane to do in Canada :nope
