Mercedes CLS 550
ssmobiletint
Posted
Took the rear seat out, popped rear pannels, and could not get the f'n headrests out in order to pull the rear deck, any suggestions. I wanted to remove this because the 3rd brake light rests against the rear glass.
:dunno
its this body style..
Guest 1PEECBARETTA
Posted
It does not come out. The dealership does not know how to remove them. Get a bulldozer to squeegee past the brake light :dunno
Guest naughtydog
Posted
It does come out...there is a special trick for the headrests - you need a pick tool and a mirror to release a hidden clip.
Posted
the headrest will lay day down flat ...there is a button to push and they lay down flat.
the bulldozer works great....makes the install real eazy.
:dunno
Guest naughtydog
Posted
We have one of these in today and there is no and I mean NO room to squeegee in behind the brake light.
Dunno what we are going to do :rollin
Struggle...
Posted
Dunno what we are going to do :dunno
It's a biatch to do but you can getter done. Use a bulldozer behind the light and a slammer for the corners. I've installed and did an R/R without deck removal. :dunno It's just not fun
Guest maddtinter
Posted
I have had the same struggles installing while the package tray is in.Removing the tray is about a 25 minute job.You only need to be familiar with Benz cars.
Guest Harry1982
Posted
has there been a 'How 2' posted on the removal of the shelf? I've got one of these in and I can't see a straightforward way of getting the shelf out
