Guest Chrisbuckner Posted August 16, 2007 Report Share Posted August 16, 2007 For all you guys with the luxury of working indoors and out of direct sunlight, here's a trick I developed back in my in-the-shop days during the winter when the pop-ups are at their worst. I started keeping a 70% water/30% alcohol hand sprayer in my arsenal to aid in adhesion. 70/30 is the best ratio I've found to avoid burning the glue. After cleaning and wetting the glass normally I spray the 70/30 onto the glass, roll on the film, turn on the defroster, and wait approximately one minute before starting to squeegee(strictly blue max and side swiper for me). Adjust wait time as needed. Try it, you'll be amazed at the difference. Also as an added bonus since the alcohol softens the glue, you will be able to rub in dirt or creases(me?! Never! ) more easily and often without any heat necessary. Have fun out there! This post has been promoted to an article Link to comment Share on other sites More sharing options...
Guest tintdawg Posted August 16, 2007 Report Share Posted August 16, 2007 Very cool, thanks for sharing. Ill keep that in mind. Link to comment Share on other sites More sharing options...
Ryker Posted August 16, 2007 Report Share Posted August 16, 2007 I had the pucker problem using the Sungard Slate, but since I switched to Llumar ATR I hardly EVER have any. I also use Film-on at a very low slip. If I let my window sit for more than a few minutes the film is stuck enough that I can't squeegee it out...... I am sure the tip will help some though.... happy tinting Link to comment Share on other sites More sharing options...
TintDude Posted August 17, 2007 Report Share Posted August 17, 2007 Don't forget to add the URL of your tip to the TOTW submission thread in the General forum or it won't get added to the vote. Link to comment Share on other sites More sharing options...
