Guest irishhanks2 Posted August 15, 2007 Report Share Posted August 15, 2007 ok on most old trucks if you'll notice the in side rubber is got a little bit of a grove around it makeing it bigger on the in side then the out on these I'll cut the film on the inside then take it to the table and smooth the edges over. then I"ll do a reverse roll reverse roll method and make sure you remove all crud be for you apply hope this helps Link to comment Share on other sites More sharing options...
Texastintchick Posted August 15, 2007 Report Share Posted August 15, 2007 I just never got the hang of the reverse roll. I fold my film then unfold it onto the glass. Link to comment Share on other sites More sharing options...
Guest irishhanks2 Posted August 15, 2007 Report Share Posted August 15, 2007 I just never got the hang of the reverse roll. I fold my film then unfold it onto the glass. I do that too, especially those big back windows where it is almost impossable to carry in to a car Link to comment Share on other sites More sharing options...
tint_detective Posted August 16, 2007 Report Share Posted August 16, 2007 I like doing the reverse roll onto the back glass.. Some, I will double reverse roll toward center and split the liner. Others I will reverse roll onto the rear deck and Frankenstein onto glass....Depends on the car.. Link to comment Share on other sites More sharing options...
Guest scottydosnntkno Posted March 22, 2009 Report Share Posted March 22, 2009 I like doing the reverse roll onto the back glass..Some, I will double reverse roll toward center and split the liner. Others I will reverse roll onto the rear deck and Frankenstein onto glass....Depends on the car.. Lately I've found myself doing it the 3rd way a lot. also because if I roll it too tight, a lot of the water gets squished out, so its a little tacky going on the window. If I roll it onto the back deck I can respray it real quick to get some more water on it and it goes on smoother. Link to comment Share on other sites More sharing options...
Guest Crackz Posted March 22, 2009 Report Share Posted March 22, 2009 just wet the glass good before you unroll it I reverse roll every rear Link to comment Share on other sites More sharing options...
