Guest streetsounds Posted August 14, 2007 Report Share Posted August 14, 2007 my boy got one and we cant get the the window crank off Link to comment Share on other sites More sharing options...
Mdog Posted August 14, 2007 Report Share Posted August 14, 2007 More than likely what you need to do is release the U shaped clip that is behind the crank. You can do this by prying between the handle and the panel to gain access to the clip and use a pick to pop it loose. Another way to get it off is to take a rag and wedge it inbetween the crank and panel and see saw the rag back and forth and it will grab the clip and pop it loose. Also you can go down to autozone or the like and get tool that is made for taking door panel clips off. It will work to pop the u shaped clip off also. If you dont see that it may have a hidden cover on the handle itself. see if you can find that and there may be a srerew hidden behind the hidden panel. more than likelt its going to be the first scenario I talked about. Link to comment Share on other sites More sharing options...
Guest streetsounds Posted August 14, 2007 Report Share Posted August 14, 2007 I have a crank remover tool I just cant get it off drivn me nuts Link to comment Share on other sites More sharing options...
Guest GETITWET Posted August 14, 2007 Report Share Posted August 14, 2007 it might have a pop off cover on the front with a nut behind that, if you can't see the clip Link to comment Share on other sites More sharing options...
BRITEworks Posted August 14, 2007 Report Share Posted August 14, 2007 if it has a clip I use a door panel tool and a pick Link to comment Share on other sites More sharing options...
running free Posted August 14, 2007 Report Share Posted August 14, 2007 Be careful not to scratch the panel! I've done it, the panel is made with a plastic that scratches very easily. Even your fingernail can scratch it. Just speaking out of experience. Link to comment Share on other sites More sharing options...
tintinater Posted August 15, 2007 Report Share Posted August 15, 2007 It could one where the whole crank is a cover for a smaller crank underneath, those one's always mess me up Link to comment Share on other sites More sharing options...
Guest mhun9180 Posted August 15, 2007 Report Share Posted August 15, 2007 my boy got one and we cant get the the window crank off It has a clip, but is extremely hard to find and get off. I had one last week and it took me 10 mins on one door to get it off. Use a rag as MDog said. It works better than the clip remover. Good luck Link to comment Share on other sites More sharing options...
hoosierwindowtek Posted August 15, 2007 Report Share Posted August 15, 2007 A hook-ended pick tool works well for removing those clips, I think. Link to comment Share on other sites More sharing options...
Guest streetsounds Posted August 15, 2007 Report Share Posted August 15, 2007 thanks guys Link to comment Share on other sites More sharing options...
