suntint Posted July 23, 2007 Report Share Posted July 23, 2007 I have a customer with a skylite that causes heat and glare trouble. The problem is the skylite is wired glass. I wouldn't consider film on the inside due to breakage issues - but thought silver reflective film on the outside would be OK - most of the heat would be reflected away and not absorbed into the glass. Does anyone have experience with film on wired skylites? Link to comment Share on other sites More sharing options...
Guest Olfablade Posted July 24, 2007 Report Share Posted July 24, 2007 They'll break with ANYTHING installed interior or exterior Link to comment Share on other sites More sharing options...
TINT Posted July 24, 2007 Report Share Posted July 24, 2007 which skylites are safe to install on the inside? I went to look at a job with two skylights, one was cracked and it had some 50% film on there, it was a double pane glass. but it seems they left the craesed film on purpose to confuse who ever works on it. what is safe to put on, how do you determine what to put on?? Link to comment Share on other sites More sharing options...
Guest dalabaty Posted July 24, 2007 Report Share Posted July 24, 2007 Have used an exterior silver before on skylight about 4 years ago. And hasn't broke yet Link to comment Share on other sites More sharing options...
Slick Posted July 24, 2007 Report Share Posted July 24, 2007 Have used an exterior silver before on skylight about 4 years ago. And hasn't broke yet but was it wired? Link to comment Share on other sites More sharing options...
Guest dalabaty Posted July 25, 2007 Report Share Posted July 25, 2007 but was it wired? Definitly, it was wierd cause in Colorado you don't see too much of that Link to comment Share on other sites More sharing options...
H.G. Posted July 25, 2007 Report Share Posted July 25, 2007 how big is the unit? I have framed in a piece of glass (pre-tinted) with no problem.frame two sides ,angle the glass in ,then frame other two sides. make sure you pre-drill everything . I have done a few like this ,no problem Link to comment Share on other sites More sharing options...
