Need software suggestions
Guest StudioSP
Guest StudioSP
I've been using CASmate-Pro for cutting, but I think this program is a million years old. I'm not able to import the stuff I should be able.
Sooooo, I'm in the market to actually buy software.
I use Flash 7 for most of my design work, and want to easily save/import into the plotter program. I have a lot of .EPS files I would also like to easily import w/ out issue.
Any suggestions would be great. I do use a PC platform, but it would be cool if I could also run something in Mac OSX
We use flexi, illlustrator and photochop...
Mostly I use flexi, very powerful program with lots of cool features.... once you figure them out....
I would sugest formal training before you decide to buy it, because it isn't a 'cheap' program, but IMO well worth the mulla!!!
Guest StudioSP
But you're not using Illustrator or PS to export to the plotter..... Flexi is your 'plotter program'?
Most of the programs I've seen are only around $500.
do you do any digital? dont know if the other programs have this or not but the new signlab that I use can actually print perf. film....you dont need to buy perf, which we all know is expensive :hmmm just print it on clear. :hmmm
Guest StudioSP
It took me about 5 readings to get through this......
Are you talking about that vinyl that's put on the windows of vans or other big windowed vehicles? So you can still see out of the window (from inside the vehicle) while having an image on the outside.
