Guest Peja43916 Posted May 29, 2007 Report Share Posted May 29, 2007 I just got the Blue Maxx Blade and I was wondering if anyone who has used this ever scratch or tear tint due to the sharp corners and edges of the tool. Also the tool is pretty hard . Thanks in advance for any help or info. Link to comment Share on other sites More sharing options...
Guest CajunTinter Posted May 29, 2007 Report Share Posted May 29, 2007 Blue Maxx is awesome.... Never had a problem with it... keep the film wet when using and you'll be fine !!!! Link to comment Share on other sites More sharing options...
Guest thatsnappyguy Posted May 29, 2007 Report Share Posted May 29, 2007 I have had some instances where the tint got torn by the blue max. I like the white max alot better. its not as hard and it gets alot of the water out just like the blue max. Link to comment Share on other sites More sharing options...
Guest mhun9180 Posted May 29, 2007 Report Share Posted May 29, 2007 Make sure you don't bang it into anything sharp because once you mark the leading edge it will scratch. Link to comment Share on other sites More sharing options...
Guest Peja43916 Posted May 29, 2007 Report Share Posted May 29, 2007 I have had some instances where the tint got torn by the blue max. I like the white max alot better. its not as hard and it gets alot of the water out just like the blue max. Really? Maybe I will look into ordering the White Maxx Blade if it is made of softer material. Thanks. Link to comment Share on other sites More sharing options...
Ryker Posted May 29, 2007 Report Share Posted May 29, 2007 Blue maxx is the best power squeegee for auto. It will not tear film unless you pick up some sort of crap....the blade itself will not tear film. Now if you are using some really cheap thin film then you might have more issues..... I tried a clear maxx once and it left behind a lot of water..... Link to comment Share on other sites More sharing options...
Guest Zrok Posted May 30, 2007 Report Share Posted May 30, 2007 keep the film wet and it'll do ya right catch a bug or a hunk of dirt and it'll rip a hole in your back glass keep the edge in good order (or cover w/ a wet paper towel) and you'll be fine Link to comment Share on other sites More sharing options...
Guest Key West Posted May 30, 2007 Report Share Posted May 30, 2007 Really? Maybe I will look into ordering the White Maxx Blade if it is made of softer material. Thanks. Blue Max all the way. The whole point of the excercise is get AS MUCH water out. Softer aint gonna do that. I'm sure that a white max will give great results, but it win't out perform the blue. And, ya pretty much gotta TRY and tear film with a blue max. Link to comment Share on other sites More sharing options...
Guest darkdan Posted May 30, 2007 Report Share Posted May 30, 2007 Blue max + crusher handle is what I've been using lately. Only ONCE has it ruined a piece of film. I was doing an 82" wide arch window and a piece of sand was between the film and window. Ripped a nice hole into it. Back when I had it in an unger handle I managed to catch the screws on the handle on the window a few times. Link to comment Share on other sites More sharing options...
carolinatinter Posted May 30, 2007 Report Share Posted May 30, 2007 damn thing scratched 3 windows today... edge was eaten up bad. you can flip it and rotate it so technically you have 4 sides out of one section Link to comment Share on other sites More sharing options...
