Dry Shrinking or Wet Shrinking
Guest amax28
Guest amax28
Doing a big curved back window which one do you prefer wet shrinking or dry shrinking? and why................................
:rollin
  • Replies 29
Guest wilz
This is a good one :rollin
Before I do anything, I like to screw it up 2 or 7 times. :rollin Actually I agree with tintman on all points. :beer As far as why?... wet shrinking seems to keep the film cooler and alows for more precise manipulation although at the cost of being much more time consuming. I'll sometimes dry shrink till I get to those heavy curves, then wet shrink the rest. :dunno BTW welcome to the board. :dunno
I almost always dry shrink. I only use wet when doing something like a Cherokee or small glass on a convertible.
When wet shrinking, the film does not shrink evenly. Fingers are usually restrained and do not freely move around to allow more even shrinking. Also, some may have noticed that after you do the first shrink (wet) then you do your final cut, you may have some small fingers pop up that need more heat. This is because the first shrink "trapped" the unshrunk area "inside" the edges. When you cut the edge, you have cut off the part of the film holding the part together that still needs heat. Make sense?
Dry shrinking allows the film to move around more freely and distributes the heat better. Film doesn't need to be "cool". The water in the wet shrink makes it harder to shrink because it takes longer for the film to heat up and shrink. Also, I've noticed that since I started dry shrinking, 95% of the time I do not need any heat after I've hung the film. Vice-versa, I needed some touch-up heat MOST of the time with a wet shrink.
As for dry shrinking, then wet checking....if you need to do this, you are not using enough soap (if that's the method you use). When I get done dry shrinking, the film looks like I used water. Completely smooth and flat on the glass. No need for wet check.
I would be willing to bet that more film/adhesive failure would occur as a result of wet shrink rather than dry. Neither may cause any problem, but if one did, I'm leaning towards wet being more stressful.
