How can I do this???
Guest 67camaro02
Guest 67camaro02
Posted
Ok, I don't normally do flat glass (I've done 6 small commercial jobs all under 300 sq ft) my bread and butter is automotive. Anyway, my question is this....
It's the front of a gym and they want people to not really be able to see in. I know reflective would work well during the day, but at night they'll be able to see right in. Do you think it would work if I did 20% reflective Gold with a 5% reflective grey behind it?
Thanks in advance for the help :lol6
Guest tintslut
Posted
yeah, that sounds about rite, welcome aboard, I look forward to many more of your straight forward solutions.
Guest metint
Posted
Ah sl*t... you disappoint metint4u2 :bs
67,
There is no way to obtain window film privacy after dark as long as the lights are on inside...
Except, of course, if you were to use a frost/semi-opaque film, which does not allow visiblity in or out, but does allow some visible light to transmit through.
:lol6
Guest 67camaro02
Posted
Yeah TS I guess my question was not real straight forward. So, what you are saying is it would be a waste of material. I know that if there is a light source behind the tint it doesn't appear to be as dark. But I read on here where somone else did a reflective doubled over too make a privacy mirror effect. Guess that was in a place with the lights off. I dunno, like I said I'm a novice when it comes to flat glass.
I have never used the blackout/opaque. If I were to use that they can't see in or out right? Is there no way to make it even remotely private? I really do need some help guys...
metint you said something about frosted, what if I put that behind the 20%?
Guest tintslut
Posted
someone search for james bond and my user name to see my thoughts on thsi subject..
Metint,, Me so sorry to dissapoint,,,, :bs
67's solution sounds eeeerrrriiiilly familiar to TBF30 :lol6
Guest metint
Posted
:lol:thumb No need to piggyback 'white' frosty and I didn't even mention blackout because it is very risky in terms of thermal stress. Keep it simple...
sl*t... good point about tbf30, however, it does mention lighting in it as well. I guess I misunderstood your post? :lol
Guest S and S
Posted
I would not anything of 2 coats. if the are Double pain!!
Guest Sprinter
Posted
if it's single pain I would do the mirror tint on first and a layer of auto limo on behind it. if it's dual pain I would do the mirror and then have them install flood lights on the outside facing the door...........
Guest 67camaro02
Posted
We decided to use Johnson's SV10 and I recommended that he install a new/different light fixture outside under the awning if he wanted it to be more effective after the sun goes down.
Sprinter-thanks for the idea :woowoo
    rewiredtech.io
    2. 5
    6. 5
    7. 5
    8. 5
    9. 5
    10. 5
