shwusyrtnts Posted January 7, 2007 Report Share Posted January 7, 2007 Okay I am having a problem with some back glass and global HP films. I am having trouble with one piecein 2000-current camaros,06/07 corvette, and berreta. I have done each of these cars before with sungard as well as suntek but I cannot get the hp global to work. What coud I be doing wrong? I have changed nothing but he film I used to use. Is there a "trick" to the global or something? Please help me I have turned away 2 vettes cause of this and I dont think it is me Link to comment Share on other sites More sharing options...
Guest naughtydog Posted January 7, 2007 Report Share Posted January 7, 2007 The trick is...use another film Link to comment Share on other sites More sharing options...
shwusyrtnts Posted January 7, 2007 Author Report Share Posted January 7, 2007 Come on whats wrong with global? Link to comment Share on other sites More sharing options...
Guest willie Posted January 7, 2007 Report Share Posted January 7, 2007 Honestly nothings wrong with the film. Darkdan will be along to explain. I have the same trouble on some back glasses with the Quick dry that lays easily in CS or Suntek. Its just one of those deals Link to comment Share on other sites More sharing options...
shwusyrtnts Posted January 7, 2007 Author Report Share Posted January 7, 2007 Its almost like the "fibers/" are to tight so when I shrink it I get horizontal lines almost instantly. is this common or something I tryed sarching Global on this site and this is new for me Link to comment Share on other sites More sharing options...
Guest tinterjim Posted January 7, 2007 Report Share Posted January 7, 2007 Try MDOGS soap method. Link to comment Share on other sites More sharing options...
Guest TINTEM Posted January 7, 2007 Report Share Posted January 7, 2007 On the Camaro's I just do the wet Method Works better for me. Link to comment Share on other sites More sharing options...
Guest MidcoastMW Posted January 7, 2007 Report Share Posted January 7, 2007 The trick is...use another film Link to comment Share on other sites More sharing options...
tintslut Posted January 8, 2007 Report Share Posted January 8, 2007 another film? Take the beretta to the junkyard. The new vette is not an easy shrink Link to comment Share on other sites More sharing options...
coolzone Posted January 8, 2007 Report Share Posted January 8, 2007 I use Global HP and havent done any of the cars you mentioned but do the soap method. It shrinks better using a larger area and not concentrating the heat very much. Horizontal fingers have shown up on every back glass I have done. I just convinced them to go vertical and it all worked out. I actually gave it some time and then came back. That is how I was able to get it shrunk. If there is a better way I need to know. Link to comment Share on other sites More sharing options...
