Window cleaning solutions
Guest REITZ20
Guest REITZ20
Posted
I tint older cars sometimes 1970-80's. sometimes I have trouble with what seems like possible chemical residue on the windows. I use baby shampoo with water now, but do I need to pre-clean the windows with something stronger first? What do you guys use? :eyebrows
Guest REITZ20
Posted
I DO USE A RAZOR WHEN I CLEAN WINDOWS BUT I'LL TRY DIRT OFF ALSO. I GET EM' CLEAN OF DUST, DIRT ETC.. BUT MAYBE NOT CHEMICAL RESIDUE FROM SMOKERS, ETC... DIRT OFF WILL WORK FOR THAT? I TRIED WINDEX, SEEMS LIKE I COULD DO BETTER WITH SOMETHING ELSE. :eyebrows
Posted
sometimes I'll use Sprayaway glass cleaner...or whatever I have in a can... :thumb
spray it on the glass first...let the cleaner do its job... cut patterns.....prep glass as-normal. lay tint.
seems to work pretty well.
:eyebrows
Posted
I use sprayaway on almost every window plus soapy mixture and razor blade and then squeegie. Maybe I dont need the sprayaway everytime but that is how I have been doing it
Guest MidcoastMW
Posted
if its close to 10 years old, I like to spray the back glass with sprayaway glass cleaner and white scrubbie the shiz out of it. Then after that repeat but use dirt off.
Guest REITZ20
Posted
I'm unable to find dirt off... what's the website, where do I get it from? x-100 site is for odor. Whazz up? :shock
