Unusual tint questions
Guest Snafu
Posted
Hi, I am a custom computer builder and need your advice on a case I'm doing for a client. The case is lexan, and the idea is to have an internal lighting system that will make the internals visible when on, but look like a mirrored surface when off. Will the mirrored auto tint I find at the local shops give me this effect? If not, what do I need to use? Any advice on proper installation of it? I stopped here in my search for tint several hours ago, and have quite enjoyed reading your forums.
Snafu
Guest TintsOvOz
Posted
:lol2 The Idea sounds ok and should work, but lexen and plastics arent very reliable to apply to :lol2
Oz......... :lol2
Posted
Excellent, thanks for the affirmation. Any particular brands I should look for? As for the adhesion, it will ultimately be sandwiched between another etched piece of lexan, and the conditions in one of my cases are far from harsh. What if I layered more than one mirror tint, will it reduce the clarity?
Guest 1PEECBARETTA
Posted
1 layer should work well, brands, I can sell you some , I have the perfect mirror film for you,easy to work with.
Guest cherasia
Posted
Snafu
What kind of a cooling system are you using in the 'puter? One of the problems you might run up against using film is the reflection of the heat back into the system. Don't wanna tick off the processor, etc. Make sure you have a really good cooling sys.
Shauna
Guest darkdan
Posted
Normally a case is made out of metal. So I don't think that should be a problem. If it's a custom case with a light show and tint.....it should have a case fan or two.
Falling off isn't the problem with film on lexan. It's outgassing that cases bubbles that can be the problem. But it's hit or miss and doesn't seem to have much rhyme or reason to it.
Posted
Well, it seems I'm not allowed to send PM's or emails on this site, so I'll ask here. I need either 20 or 24" x 6 tint in bronze, silver, mirror black and orange. Are all these colors available? Please feel free to email me: gpetersiv@insightbb.com
Posted
Also, will outgassing be a problem when I have a 24X24 inch max size?
