Best HP to match factory tints
Guest chip01
Posted
As described in relation to my earlier post. I have looked at suntek hp but buying in 60" cut 36 / 24 is going to be stock problem for us as we mostly use 24".
I have been using solar gard HP but is really reflective especially on x5, range rovers etc. What can you guys recommend, to suit and match up.
  • Replies 21
Posted
why not just buy the 24" x 100 if your not going to use the 36 :rollin
Posted
because the distributer over here only sells in 60" and you cannot buy them boxed seperatley
Posted
man that sux where are you at and what all film choices do you have then :rollin
Posted
thats only the suntek distrib, but thats what I wanted to really buy. Just a pain with the roll size though. As I say I have been using solar gard hp charc but you know how reflective that is, also can look quite green.
Posted
Hang in there
As far as Suntek goes I like the HP 35,30 and 20 to come close to matching up. I
use whatevers legal. If you can get your hands on global or Omega Plus they are also a close match.
Which factory vehicles are you trying to match most of the time :rollin
Posted
I do a lot of range rover's, x5s. I used to use the NR line from solargard but it was to thin really so I went for the hp but just to refective
Posted
:rollin I'm not familiar with range rovers here in the sticks, but the Suntek is one of the least reflective HP films Ive tried
good luck :rollin
Posted
Global HP 20 & 35 have done very well for me. If you can get some to try out I would recomend it. If not good luck and hopefully they will be able to get you what you wat.
Posted
Chip, where are you located?
I didnt get him to answer that either, but I told him about the Omega Plus, he didnt act like he could get it :rollin
