all glued up??
Guest naughtydog
Guest naughtydog
Posted
On my next tint a plan on glueing the dot matrix. I believe a clear type glue with an applicator at the end seems best.
It it better to apply the glue to the dots themselves or to the film??
When you hard card the dots, does most of the glue come out?? and just leave behind a small amount or what??
Just so I know I am going about things the right way
Thanks
Naughtydog
Guest blackglass
Posted
the glue should level out the dots, ie no air pockets, it should dry clear, and ALWAYS to the glass not the film. :mad
Guest naughtydog
Posted
that was quick - thanks.
Will there be much residue??
Silly question - I better have a crack at it myself.
Guest thetintshop
Posted
of course, you could use vinyl, and be done with it.
wow, deja vu.
Guest SQUEEGEE
Posted
Thanks
Naughtydog
ND,
I'm only replying because your Avatar (user pic) cracks me up every time I see it and is worthy of note.
I don't know if they sell Elmer's Blue School Gel in your neck of the woods but that would be your best bet because it has a squeezeable bottle with a pointed tip that can be used to apply a uniform bead or line of glue accross the bottom of the matrix.
The clear glue with the applicator that you mentioned does not work well and is quite sloppy and inconsistent.
Good luck.
Posted
I ALWAYS apply the glue to the film....I pretty much finish the window, then peel the film down from the matrix and apply a bead of glue to the film at the closest point to the window (at the bottom of the matrix). Then card the film up as I spread the glue. Works well for me. :thumb
Guest tintgod
Posted
yeah..I do the same blade.......then after ...I take a snort of glue for myself for a job well done....... :hmmm:shock:thumb
Guest PDXErik
Posted
Just a quick question, but do water-based glues like elmer's keep them looking right? should I just paint my dots before I get my tint? or what?
    rewiredtech.io
      Dealership Regional Lock Changed
      Sunscape dealers?
    3. 3
    4. 3
    6. 0
      Looking For Tint Businesses for Sale in NJ
    7. 1
    8. 5
    9. 1
    10. 0
