Tint-Off The Killer Remover
Guest darkdan
Guest darkdan
Yeah, it does a nice job.
But I found out why they call it killer. I'm redoing my crown vic today. Global doesn't like to come off, so I bagged even the side windows with Tint-Off The Killer Remover.
Not only does it remove tint adhesive rather nicely, but it also removes the adhesive that holds the felt on the side gaskets.
So I was squeeging the window clean and all the felt came off. =(
I've also found that it stains leather interiors.
I think I'm going to go back to just ammonia.
Guest darkdan
I got the stuff from 44tools. It was an impulse buy.
Global just hangs on though.
I tried my jiffy. It was still leaving a lot of glue behind. So I bagged the side windows for a while. Then I steamed them, still leaving it behind. Then I threw my lights on the rest to heat them up, hit it with the steamer....left about 20% of the glue behind.
No worries about adhesive failure there!
After the film is removed the Killer Stripper does a decent job of softening it up. It turns it yellow. Unlike other chemical strippers it says non-toxic and instead of turning the glue into a gross goo it just makes it soft.
Guest scottstinting
Sometimes if I cant steam off the tint I will steam off the glue and use a blade on the sides and it comes off like butter .The steamer will really soften the glue
    rxactlite.com
    rewiredtech.io
      What did you tint today?
    3. 4
      Dual Low E Question
    4. 4
      Dual Low E Question
    5. 9
      Any XPEL Dealers?
    6. 9
      Any XPEL Dealers?
    7. 2
      Am I being too picky or should I go back?
    8. 9
      Any XPEL Dealers?
