Pajero
Guest BlackOut
Guest BlackOut
Posted
Straight forward job, but wee bit harder if you have wind deflector on windows.
Cuts have to be made on the inside.
Only 1 rubber need to be cut on rear static window as there is huge amount of space for other rubbers to move, just bend them toward you.
I always take spare wheel of rear door and centre brake light off as well.
Shogun has TWO cargo area side windows, one of which slides-not as easy-price accordingly-the overlap is always filthy.
Hope this helps
Guest monkeyboy
Posted
These are easier than the Shogun, have a look at what I wrote for window removal under the "SHOGUN" section. With these ones the frame comes apart. Apparantly screws hold it together. Undo them pull the frame apart and the glass slides out.
This applies to the boot sliding windows.
    rewiredtech.io
    2. 6
    6. 6
    7. 6
    8. 6
    9. 6
    10. 6
