My humble Tip of the Week contribution.
Posted
I don't use this personally anymore, but is pretty functional.... to make room to slide tint behind tight door panel moldings (bottom), take the white plastic tube that the tint is rolled on (20" roll works on all doors) and cut it down the center, making a little halfpipe out of it. Stick this down into the molding, and let it hang over the door as you're tinting. It's out of the way and the tint will slide right down behind it if you wet it. It's a good little trick for people that aren't as experienced with tinting rollups with the door panel still on.
