05 accord back window problems
Guest cav444
Guest cav444
Doing a 05 ccord coupe. sides went excellent. Had a lot of trouble with the back. 1st problem was when the tint was rolled against the back window I had no room to unroll it due to the airbag equipment in the pillars? I ended up rolling it sideways, which took a lot of positioning to get in the right spot afterwards.
big problem however is I cannot fit my hand in the bottom portion of the glass near the 3rd brake. removed the deck for more room still not enough. I cannot get a card or squeegee at the correct angle to push bubbles more than 1.5" (or about the bottom most defrost line) from the edge. My big ol hands will just not fit in there. I need some kind of squeegee on a stick or something??? Any suggestions?
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
    2. 2
      Crystalline VLT question
      Optimal environment temp
    4. 1
    5. 2
    6. 2
    7. 8
    8. 8
    9. 0
      Any LLUMAR or XPEL Dealers?
    10. 7
      llumar backer branding
