Broken defroster tabs
Guest bso
Posted
I was wondering can JB Weld be used to glue broken defroster tabs? I believe it has some sort of metal compound in it, so it should be conductive. Anyone w/ experience with it?
Guest mosolarpro
Posted
it might work but just go to a auto parts store and get the glue made just for that
Posted
Super glue has worked for me....:rollin
Posted
if its broke off from the glass, there is a kit make by permatex that has conductive epoxy and conductive paint to fix that. you can get it at autozone.
Guest FastBackJack
Posted
If I ever break those off I use a soldering gun and low temp solder to put them back on. I used to use the glue but I hated having to to go buy the little packets....which can only be used once. I just sand the tab where the solder goes, drop some solder on the 2 areas, put it up to the glass and reheat it untill it melts and sticks on. But the glueing works. I just dont want them to ever come back. :lol6
Posted
Thanks for the all good advice... Now I guess I will break the next half a dozen of cars I do to see which method works best (just kidding).
I am still curious to see if JB Weld conducts electricity, but I feel I should not find out.
Posted
If I ever break those off I use a soldering gun and low temp solder to put them back on.  I used to use the glue but I hated having to to go buy the little packets....which can only be used once.  I just sand the tab where the solder goes, drop some solder on the 2 areas, put it up to the glass and reheat it untill it melts and sticks on.  But the glueing works.  I just dont want them to ever come back. :thumb
You gotta be careful with this one..the glass could go KABOOM !! "Frostfighters is a great little kit you can find on the internet ...it works great...similar, if not the same to what MDOG uses :nope
    rewiredtech.io
      Sunscape dealers?
    2. 2
      Dealership Regional Lock Changed
    3. 2
    4. 2
      Looking For Tint Businesses for Sale in NJ
    6. 1
    7. 5
    8. 1
    9. 0
    10. 0
