when ya gotta use opaque pen
take 3-4 pens and cut the metal off below the felt , a sharp dyke (no pun intended) will suffice.
drain the ink in a resealable jar ,bottle whatever ,then where you would normally use the pen,use a fine bristle camel hair brush to do the work. most tinters have "surgeons" hands ('cept after a few cups of coffee or ...
but if your carefull it is a lot faster and smoother . you dont have to keep plunging the felt ,no streak,just a smooth cover . :DD
Sounds like it's a good idea if your buying the same pen with a "thick" tip, however som brands ( I use DECO ) which can be found at Micheal's has paint pensfrom as thick as your finger to as fine as a toothpick tip for ultra fine touch - ups ..the alternative is to just have a fine/medium/wide tip on hand depending on the touch up situation :DD
Guest NokTint
I hate using this stuff... it looks cheap. maybe im using cheap pen ??? the pen is a silver casing. black writing . am I doing sumthing wrong ??
