Technically Confused
There's so many specs now I don't know the answer to this.
The best indication of which film will block more heat from entering through a window is what?
Higher TSER spec
Lower Shading Coefficient spec
Greater BTU reduction as measured on a BTU meter
Who knows the answer?
Guest vclimber
      Higher TSER spec
[*]398423
#1 & #2
#3 is only measuring a certain narrow range of IR rejection and does not give you the full picture of the film's performance.
? ? ? Higher TSER spec
? ? ? Lower Shading Coefficient spec
? ? ? Greater BTU reduction as measured on a BTU meter
[*]398423
#1 & #2
[*]398425
Thanks, VC
That's what I was thinking. So demo-ing a film with a heat lamp and BTU meter and showing an impressive drop in BTU levels can be kind of bogus.
Guest vclimber
Thanks, VC
[*]398429
Well um :? , yeah kind of. If you look at the whole picture. IR is responsible for 53% of the solar energy and your BTU meter is only measuring a certain wavelength on that IR spectrum. So it is not giving you as full of a picture of the films total performance as the TSER or the SC. But in defense of a BTU meter, it does show how film can either absorb or reflect IR which is good, kind of... :ohcrap
