rear view mount removal
Guest tint rookie
Guest tint rookie
I want to remove the rearview mirror from my personal rig. and put one down on the dash.
any suggestions for removing the mount from the glass? dont wann take a big ol chunk out of the glass like on all the ford full size.
Guest kenb81
I'm afraid you are stuck with it if you try and remove it you will break the glass.
you can try mounting the mirror and roll up the windows and face it into the sun
eventually it should fall off or you can try like a paint scraper and scrape it off but again
you make breake the glass
Yo rook! Check dis out man I always just heat the acual mirrior mount with a torch and tap it at the same time with a hard plastic hammer. I really have done this a bunch of times I do glass replacement as well and sometimes the mirrior mounts are wrong, Do all of this from the inside of course and remember dont get the glass hot just the metal piece. Good luck there friend
Guest darkdan
[*]397180
When I had my windshield replaced on my TBird that is exactly how he did it.
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
      Geoshield C2 Carbon Ventura, Ca.
    3. 2
    4. 2
    5. 2
      Crystalline VLT question
    6. 1
      Optimal environment temp
    7. 1
    8. 2
    9. 2
    10. 8
