Heat and Temperature
Guest metint
I've seen, heard and read plenty of questions related to whether or not solar film lowers temperature in a room when installed to window glass.
The below quote is something learned today and addresses the question in a very easy to understand way... :lol6:hmmm
Distinguishing "Temperature" and "Heat"
It is important to understand that temperature and heat are not the same. Temperature is simply (or not so simply) a measure of the intensity of molecular motion, how rapidly the molecules comprising a material object are jostling about. Heat is a unit of energy. The tiny flame of a butane lighter can be at the same temperature as a forest fire, but forest fire is generating vastly more energy. The greater the volume of mass at a certain temperature, the greater the amount of energy (heat) it carries. Window films alone cannot "lower the temperature of a room," but rather reduce the rate at energy enters or leaves the room and thus help the AC system lower the room temperature by reducing the work it is required to do. The greater the glass area, the greater the impact window film can have on heat transfer into or out of a room.
Oh and ah... courtesy llumartech.com... sorry I forgot this.
http://coolcosmos.ipac.caltech.edu/cosmic_...ermal/heat.html
http://coolcosmos.ipac.caltech.edu/cosmic_...emperature.html
http://coolcosmos.ipac.caltech.edu/cosmic_...mal/differ.html
  • Replies 22
Guest vclimber
Yep big misconception in the industry.
Remember, air conditioners cool rooms. Window film helps reduce the TSE entering the room thus helping your a/c to do it's job more efficiently.
Metint -
I hereby grant you permssion to attach the pm I sent you, to this quote with, no copyright recourse.
It is time these guys and gals know that I am the trued source of your knowledge.
:hmmm
Especially since it sounds like they agree :lol6
Guest vclimber
Well somebody got that from Llu Llu Tech so they should be referenced as well.? :lol6
[*]365485
cmon dude give me some props on something :spit
[*]365497
Didn't mean to :DD
:lol6
Well somebody got that from Llu Llu Tech so they should be referenced as well.? :DD
[*]365485
cmon dude give me some props on something :lol6
[*]365497
Didn't mean to :DD
:lol6
[*]365501
yeah right :spit I dont mind being the whippin boy when I deserve it
Guest tintgod
The below quote is something learned today and addresses the question in a very easy to understand way... :lol6? :lol6
[*]365466
may I use that quote?..who's ever quote that is.. :spit
