Newbie Help
Posted
I just started tinting about 6mos ago. I always thought that pickup trucks would be the easiest to do.NOT.LOL. im having the hardest time cutting out the rear sliding window were the handle is attached. Any tips??
:DD
Posted
welcome dude :DD
which truck? does the latch have the black border?
Guest tint rookie
Posted
use scrap clear liner to make a template 1st.
[*]363976
werd
plus, some latches have hard clear adhesive gooped up past the latch. carve that excess chit out while youre blading.
Posted
again which truck which slider
then we will glad and able to tell you more
Posted
[*]363984
Any of them really Im just havin a hard time free handing it.
Guest imfear44
Posted
[*]363976
Sorry What is a scrape clear liner???
[*]363997
its the clear backing off a piece tint, try cutting patern from the inside
Posted
I agree, release or clear liner would be the best bet trace out pattern on inside with liner then trace again on glass and tint to make pattern out of film. Hey I could just sell you a pattern if it gets to rough for ya :lol2 !! HA-HA
Guest Beeline
Posted
open the window about an inch. line the tint up on the outside. cut out latch. take tint to the inside. line the tint up on the latch(make sure liner is facing glass). slide tint away fron the latch about an 1/8 inch. cut top and bottom. cut back using the edge of the glass. take tint off clean and stick. tint should line up on the latch and you should hav :lol2 e an 1/8 inch gap int the back.
