dot matrix
Guest andyt
Hi guys been tinting now for just over two years all sorted but bloody dot matrix. Sometimes I do a ford focus quarters one side perfect other side air line all round :dunno same with vauxhall corsas
how come? is it how far back u trim or too much shampoo in the solution. need help I`m using suntek metalized cheers in advance. :thumb
after it drys out is it still stuck to the dots?
sometime if all the water isnt out it can look like its stuck but when it drys, its shows white.
[*]362654
the side that took stays stuck looks great.
Guest JJ-TINTS
wait until completely dry then they should both look real close to the same - if not run your finger over them
[*]362675
and use a heat gun and paper towel to push out the water.
[*]362680
use LESS solution m8 that should help :)
works wonders on the citroen/pug yoks too
