Window Film/Adhesive Remover
Posted
since now im a millionaire, I might as well share the fortune/wealth.
after removing film there is adhesive left over right? right.
this solution is mostly for back windows, where youhave the defroster elements so is sometimes, not a good idea to use a scrub pad, steel wool, or even a razor :dunno
spray some of this stuff on back window or sides, let it sit for about 10 minutes, without heating (you can if youwant) and when you come back to check it the stuff becomes into water! literally! try it.
its called TINT-OFF and they are based oout in FL. 1-888-846-8633
you'll thank me later
Guest vclimber
Posted
Does that prune juice work on CDF? :dunno
I will thank you for sure if it does. :thumb
Guest tintgod
Posted
this is a joke right?.. :spit
this stuff has been around for years..nothing new here. :thumb
but I will have to say...it does work good on some adhesives..but not all :dunno
Guest vclimber
Posted
this is a joke right?.. :lol
but I will have to say...it does work good on some adhesives..but not all :spit
[*]362615
I :dunno Tint's avatar is always smiling at me. :poke
If it can put a dent in dry adheasive without killing the installer or eating away at the window frame then someone is going to make a lot of money.
Guest tintgod
Posted
this is a joke right?.. :thumb
this stuff has been around for years..nothing new here. :dunno
[*]362615
I :lol Tint's avatar is always smiling at me. :poke
[*]362617
I have used it...and it has a really bad odder to it...you do have to delute it ..and it will streak on door panel and molding if you dont wipe it way before it dries :poke
Guest tintgod
Posted
but I will add..it does work great when sweating..but be sure to wipe the excess off before it dries on any molding :dunno
Posted
this is a joke right?.. :dunno
[*]362615
then you havent used it for a long time like you say "for years" it does work for all.
but I will have to say...it does work good on some adhesives..but not all :poke
[*]362615
I :dunno Tint's avatar is always smiling at me. :bingo
[*]362617
[*]362620
not as bad "ODOR" like your armpits? :lol2 the scent is strong but that is why its good stuff to use when it comes to removing adhesive.
but I will add..it does work great when sweating..but be sure to wipe the excess off before it dries on any molding :thumb
[*]362622
well shiat man, anything will leave marks or streaks, even water. :poke
maybe the stuff youwere given was cat p1ss :lol
