Guest keepitcool Posted January 12, 2006 Report Share Posted January 12, 2006 ok so im bidding against this guy here and his big selling point and reasoning why he charges so much is because he takes out the seals and installs the film all the way to the edge of the glass he says to" avoid glass breakage problems by eliminating the gap of clear glass around the edge so that there isnt a difference in heat retention in the window" and also so there is no " ugly gap" around the edge. sooooooo what do you do on a wood framed window??? take a sawsall to it?this is the kind of @#$% I have to deal w/ here. along w/ some dumbass old man selling v$sta film for 2$ a square and under. Link to comment Share on other sites More sharing options...
Guest TintsOvOz Posted January 12, 2006 Report Share Posted January 12, 2006 I also do the gasket technique, have for ever now, you get a tinted glass look, dont know about the heat speal :inot ? with the wooden doors etc we have some wood turner tools that get rid of 1-2mm of timber and silocone paint etc, no gaps nice!!!as for the cheepys they will always be with us unfortunatly rise above them a get good selling techniques... Oz........... :inot Link to comment Share on other sites More sharing options...
Guest keepitcool Posted January 12, 2006 Report Share Posted January 12, 2006 im interested in the wood turning tool Link to comment Share on other sites More sharing options...
Guest TintsOvOz Posted January 12, 2006 Report Share Posted January 12, 2006 im interested in the wood turning tool [*]360071 :inot not good at postin pics, but it basically 5-6" long wooden handle with a 1"long V shaped steel bit on the end that has been sharpened the V would only 2-3mm each V, dont even know the proper term, used to carve wood sculptures.. Oz........... Link to comment Share on other sites More sharing options...
Guest vclimber Posted January 12, 2006 Report Share Posted January 12, 2006 How dark is the film that you want to put up? If it is 50% or lighter, the gap should not be a big deal... Old guy selling Vista for $2.xx/ft will probably keel over and die because he aint gonna make a living selling it for that much. we all know how much it costs. Link to comment Share on other sites More sharing options...
Guest vclimber Posted January 12, 2006 Report Share Posted January 12, 2006 ok so im bidding against this guy here and his big selling point and reasoning why he charges so much is because he takes out the seals and installs the film all the way to the edge of the glass he says to" avoid glass breakage problems by eliminating the gap of clear glass around the edge so that there isnt a difference in heat retention in the window" and also so there is no " ugly gap" around the edge. sooooooo what do you do on a wood framed window??? take a sawsall to it?this is the kind of @#$% I have to deal w/ here. along w/ some dumbass old man selling v$sta film for 2$ a square and under. [*]360065 It looks nice but it will not prevent weak glass from cracking. Besides, if you are consulting the F2G chart and follow the guidlines, breakage is not likely to happen. Link to comment Share on other sites More sharing options...
Guest TintsOvOz Posted January 12, 2006 Report Share Posted January 12, 2006 How dark is the film that you want to put up?If it is 50% or lighter, the gap should not be a big deal... Old guy selling Vista for $2.xx/ft will probably keel over and die because he aint gonna make a living selling it for that much. we all know how much it costs. :inot [*]360073 I agree light films no probs, only sorta 60% and up :inot Oz.......... Link to comment Share on other sites More sharing options...
Guest vclimber Posted January 12, 2006 Report Share Posted January 12, 2006 im interested in the wood turning tool [*]360071 :inot not good at postin pics, but it basically 5-6" long wooden handle with a 1"long V shaped steel bit on the end that has been sharpened the V would only 2-3mm each V, dont even know the proper term, used to carve wood sculptures.. Oz........... [*]360072 You mean a chisel? No way, you've really tried that on glass??? Link to comment Share on other sites More sharing options...
Guest TintsOvOz Posted January 12, 2006 Report Share Posted January 12, 2006 im interested in the wood turning tool [*]360071 not good at postin pics, but it basically 5-6" long wooden handle with a 1"long V shaped steel bit on the end that has been sharpened the V would only 2-3mm each V, dont even know the proper term, used to carve wood sculptures.. Oz........... :inot [*]360072 You mean a chisel? No way, you've really tried that on glass??? [*]360079 I think a chisel is just the flat type, this is a V shape?? not sure if the Ozy term is different??? so you are hard up against the wood and guiding on top of the glass, pressure is on the wood. :inot :inot Oz.......... Link to comment Share on other sites More sharing options...
Devil with bad attitude Posted January 12, 2006 Report Share Posted January 12, 2006 ok so im bidding against this guy here and his big selling point and reasoning why he charges so much is because he takes out the seals and installs the film all the way to the edge of the glass he says to" avoid glass breakage problems by eliminating the gap of clear glass around the edge so that there isnt a difference in heat retention in the window" and also so there is no " ugly gap" around the edge. sooooooo what do you do on a wood framed window??? take a sawsall to it?this is the kind of @#$% I have to deal w/ here. along w/ some dumbass old man selling v$sta film for 2$ a square and under. [*]360065 Look all I can say is "goodonthebloke" for setting himself apart from all of whom he would consider as being normal tinters. Let's just hope he gets a good price for the jobs he quotes as this can only lift profitability for all. Devil Link to comment Share on other sites More sharing options...
