Guest whale hung Posted November 19, 2005 Report Share Posted November 19, 2005 I try to keep cars over night from mid november till about mid march due to cold weather... if the customer has an attatched garage or better yet a heated one I will tell them to pick them up at the end of the day....it sucks to try and find space for over nighters but it is way better than giveing them back and having them frost up over night and the moisture freezing....a 2.5 hour job usually takes an additional hour to hour and half during the cold weather months....and we keep the tint part of the garage cooking all winter ....good luck with the cold months.... [*]339070 thanks Link to comment Share on other sites More sharing options...
Devil with bad attitude Posted November 19, 2005 Report Share Posted November 19, 2005 Wet door seals = popping water fingers. I'd be pulling for sure in that climate. For the time it may initially cost you, you could save that in redos. Devil Link to comment Share on other sites More sharing options...
TintWizard Posted November 19, 2005 Report Share Posted November 19, 2005 I try to keep cars over night from mid november till about mid march due to cold weather... if the customer has an attatched garage or better yet a heated one I will tell them to pick them up at the end of the day....it sucks to try and find space for over nighters but it is way better than giveing them back and having them frost up over night and the moisture freezing....a 2.5 hour job usually takes an additional hour to hour and half during the cold weather months....and we keep the tint part of the garage cooking all winter ....good luck with the cold months.... [*]339070 Wet door seals = popping water fingers.I'd be pulling for sure in that climate. For the time it may initially cost you, you could save that in redos. Devil [*]339093 Link to comment Share on other sites More sharing options...
blade Posted November 19, 2005 Report Share Posted November 19, 2005 a few extra minutes with a heat gun in the problem areas Link to comment Share on other sites More sharing options...
Guest mikeys Posted November 20, 2005 Report Share Posted November 20, 2005 Watch out for cold windows with small cracks when useing heat gun I thought the back window was warm enough till the crack grew Link to comment Share on other sites More sharing options...
Texastintchick Posted November 20, 2005 Report Share Posted November 20, 2005 a few extra minutes with a heat gun in the problem areas [*]339108 We also have a heat lamp that we put on each window for several minutes Link to comment Share on other sites More sharing options...
TINT Posted November 20, 2005 Report Share Posted November 20, 2005 removing panels woudnt hurt once in a while Link to comment Share on other sites More sharing options...
Texastintchick Posted November 20, 2005 Report Share Posted November 20, 2005 removing panels woudnt hurt once in a while [*]339208 Sometimes you just have to. But I personally avoid it at all cost Link to comment Share on other sites More sharing options...
TINT Posted November 20, 2005 Report Share Posted November 20, 2005 removing panels woudnt hurt once in a while [*]339208 Sometimes you just have to. But I personally avoid it at all cost [*]339210 everytime I have to remove panels I say to myself "why? why oh why?" Link to comment Share on other sites More sharing options...
Guest metint Posted November 20, 2005 Report Share Posted November 20, 2005 Soap to water ratio different in the South... Link to comment Share on other sites More sharing options...
