Air bubbles in Tint HELP
Guest bobthepainter
Guest bobthepainter
Hey all,
Recently my power windows in my passenger side have been acting up and the window has been moving extremely slow. I thought it was the motor at first but it turned out to be a grease build up.
Anyways the grease built up on the corner of the window and made the window stick to the car. When the door was opened the grease made the door stick and I think it "pulled" at the window tinting.
There are now a bunch of tiny air bubbles in the corner of the window where the grease was. Is there any way to get these out or does the window need to be re-tinted?
Thanks
PS: The car is a 95 chevy camaro
Guest bobthepainter
I will post a picture as soon as I can to give you guys more of an idea what happened. Someone told me I could possibly just poke the air bubbles with a small needle?
If there's nothing wrong with the existing film except one bubble, pop it with a pin and press the are to the glass. Despite what some believe, it will not peel... if you pop it with a chisel, yes, needle... :lol
If there are many bubbles and edge lift, take it in and have a pro replace it... prices vary through out the country, best to lift that 500lb phone receiver, call a shop and ask price.
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
      Geoshield C2 Carbon Ventura, Ca.
    3. 2
    4. 2
    5. 2
      Crystalline VLT question
    6. 1
      Optimal environment temp
    7. 1
    8. 2
    9. 2
    10. 8
