2005 PT CRUISER
Guest maura
Guest obsessedwithcars
Those wings really aren't that bad.What you have to do is heat shrink on the out side of the wing, because there are fingers.You also must make your inside cut against the rubber perfectly straight because there aren't seals to tuck into.When applying that wing be careful because the film will move around a bunch being as it is a tight spot.Squegee what you can and then grab a slamer card and knock the rest out between the glass and the bar.
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Smart Tint Training
    2. 2
      Under hood paint repair after Xpel removal--opinion on my idea requested.
      Geoshield C2 Carbon Ventura, Ca.
    4. 2
    5. 2
    6. 2
      Crystalline VLT question
    7. 1
      Optimal environment temp
    8. 1
    9. 2
    10. 2
