Need info on tinting a new skylight!!!!!!
Guest Nitrousoxide764
Newbie here I guess you could say. Got a new shingled roof this week along with a brand new skylight. Replaced the old plastic bubbled one. New one lets alot more light in. Would like to shade a little light out and maybe cut down on some heat gain. The skylight is double paned with tempered glass on both panes. Each piece of glass is 7/8 of an inch thick with argon and a moisture wick sealed between the two. I was planning on tackling this job myself since it's only a 19 inch by 19 inch square. I usually tint my own back windows on my little toyota trucks so I have some basic knowledge. I have enough 35% silver reflective tint left over to tackle the job. It is llumar brand automotive film. I'd just like to hear from the pros wether this would be a good choice of tint for my skylight to be safe. Also, should I leave a little light gap around the edges? I would h@te to see it explode on me. I am in the southeast with many 100+ degree days during the summer. I would appreciate ANY insight as soon as possible. I want to try to knockout the job tomorrow morning while it is still cool. THANKS!post-15602-1127162111.jpg
Guest windoworx
I have filmed many a skylight using R-20 (mostly)and R-35. Since I don't do auto film I can't say for sure but using a PS adhesive film on a skylight would seem to raise the degree of dificulty to the nth degree. Good luck.
PS. does newbie = never did flat glass before?
I did pick up in your post that it is LLumar (reflective) automotive? Call the factory and ask them whether or not you should be installing Platinum Plus on 7/8 inch tempered. 800.255.8627 ext. 3366
Thanks for the tip metint but I guess you could say it is too late to call. I just got finished with the skylight. It turned out pretty good for a novice tinter I think. The end result is exactly what I was looking for...............a bit less sunlight getting into the bathroom. We are supposed to have a heat index of 105 degrees today. If no glass breaks today it should survive from here on out. Here is a before and after shot. Thanks for everyones input!!
[*]316070
I checked today and the answer was, "Doubtful the glass is that thick per pane, but none-the-less tempered, no worries, even if it's auto tint. Just no warranty."
Second that nice before and after shots...
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
      Geoshield C2 Carbon Ventura, Ca.
    3. 2
    4. 2
    5. 2
      Crystalline VLT question
    6. 1
      Optimal environment temp
    7. 1
    8. 2
    9. 2
    10. 8
