help with a 93 sable
Guest JesterRob04
Guest JesterRob04
I have been trying to ting my rear window on my 93 sable and I have gone throught 2 sheets of tint. so I decided to research this a lil bit some people say to use just one single pieace and others say to cut it in strips is there a trick to puttin the tint on? every time I get a bunce of air bubbels that I cant get out and when I go over them with the squeegie it makes a crease I cant get out can some one please help me thanks Rob :thumbdown
  • Replies 28
Basically what you are doing, is trying to wrap a piece of paper around a basketball with wrinkling the paper.....it isn't going to happen.
Read up on shrinking/heat forming. It's the only way most back windows can be done in 1 or 2 pieces without having to run 6+ strips across it....it takes alot of practice, but good luck :bingo
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
    2. 2
      Crystalline VLT question
      Optimal environment temp
    4. 1
    5. 2
    6. 2
    7. 8
    8. 8
    9. 0
      Any LLUMAR or XPEL Dealers?
    10. 7
      llumar backer branding
