FORD FIVE HUNDRED
Guest Jason
Guest Jason
Posted
How the hell do you get the brake light outta these things :lol
Even if I cut it out, theres still two rubber nubs in the way. I tried sliding the tint by those nubs and damaged it in the process :popcorn:shower I could always cut it a little higher above the nubs, but that would leave a light gap visible from the drivers seat... unacceptable.
I have already broken all 4 plastic screws that come thru the top of the trunk (whatever, replaceable) . Ive tried prying it every way possible with no luck .
This was such an easy car to tint too- god damn ford design team can suck my nuts- why make a rear brake light so hard to take out??? what if the light burnt out?
I dunno, but im going to lose it soon- damn cars due first thing in the am.
Any help?- It would be appreciated.
:lol
  • Replies 46
Posted
I haven't done one yet, but if they are like the old Taurus, the seat has to come out to remove the deck. Just guessing, but something to consider. :popcorn
Guest ninjatinter
Posted
This may not help, but I did one about 4 months ago. I did not cut out the tail light, however I don't recall hoe the light came out. Have you popped the trunk, and looked up there? If not , I am sure Old T is correct. :popcorn
Guest ninjatinter
Posted
Hoe the light came out. HAHAHAHAHAHA oops
Guest Jason
Posted
I dont know hoe :shock the light comes out either. there is 4 white plastic screws that come thru the top of the trunk... you would think that if you removed them the light would just pop out... nope... must just be a decoy.
I just said fuk it and cut off the rubber nubs protecting the rear glass. done.
thanks anyhoo :lol
Posted
I've done 2 of those damn things and just used my swiper and ripped those stupid rubber things off :shock
Posted
I did one yesterday and for whatever reason ford has mated that plastic housing for the 3rd brakelight to the rear deck :spit it looks like it would come off but I couldnt get it for nothing. I folded down the top of the backseats and popped 3 plastic clips ( one in th emiddle and one on each side behind a side seat bolster) and grabbed the deck and pulled it back just enough to get behind it :mad the whole car was easy except fot all that bullshivet. the next time I guarantee I will cut around that damn light, no problem fvck it. typical ford.
Guest tintgod
Posted
this is all I had to take out the first one I did.. :spit
Posted
That &*(%$ Ford pissez me off so much..it's true..this car is easy and straight forward...till som asshat had to come up with the way TG shows for putting in a brakelight instead of something simple like depressing a plastic clip or hacing 2 exterior screws.(how hard is THAT to figure out guys)
The car tricks you ...you think"finially they did something right" ...till you try and remove what APPEARS to be a simple breaklight .
Ford...I hope your reading this. :spit:mad
